Hello all. First post here. I just came into a UK made ABM 500 EVO III. It was broken when I got it so anything is possible since a previous repair was attempted. The layout for the EVO III is different than the EVO II and so far I have not been able to locate a schematic for the APC056 Issue 2 2008 preamp. pcb. Believe me, multiple searches have been done. I have a request in at Ashdown for it.
The Good:
Power amp and transformer check good.
Test signal output at speaker good and clean when signal is applied at power amp section from preamp
+/- 15vdc is good
High Voltage to preamp tube is good.
VU meter responds nicely
I can trace a test signal with scope cleanly through the eq and at tuner jack.
The Bad:
A couple of sections of the common reference lands were flaked off on rear I/O pcb and on the preamp. No indication of anything burnt or arced. Looked more like poor adhesion of the copper to the glass. I have repaired those with wire.
The DI XLR hums when connected to am outboard headphone amp. No test signal present.
No test signals present at FX send or Line Out
No amplification of test signal when applied to the FX Return or Line In Jacks.
I have come to the conclusion that the preamp is the culprit but none of the schematics available in the web are helping out. I really don't want to go in and shotgun this if I can avoid it. Seeking help and advice.
Thanks,
....Chris
The Good:
+/- 15vdc is good
The Bad:
Thanks,
....Chris
