I recently picked up a B25. I think it is from the late 60s. It is rough cosmetically but intact and working with a small background hum. All graphics are gone from the face plate.
It was modified in 1996 to run EL34 (and similar 6L6, etc) output tubes.
My questions at this time are mostly sanity checking in nature. When I pulled the chassis out I noticed the following.
A 100K pot has been installed inside the amp to adjust (not sure what is being adjusted?) for the type of output tube used.
One of the 30uf 600v caps is leaking. I ordered a pair on eBay.
Pin 4 of each EL34 has a 1K 5w resistor, each resistor had a cold solder joint to the point where I was able to wiggle them off the pin. I can guess the weight of these resistors could have caused the solder joint to fail over time. One of the resistors is open. I will be ordering a pair of new resistors this week. I did not see these on the original schematic, I guess adding these was a good thing.
Once I get all my new parts installed I will take voltage readings on all the output pins and report back on those for your feedback.
Thank you
Thank you
