hartke_ha3500_power_amplifier_sch.pdfThis is a Hartke 3500 I'd bought the output module from Enzo sometime last year. Been playing ok no issues.
It was hooked up to an ampeg 8x10 cab(4ohm I believe) and now no output.
Looking over the output board q310 looks to have arced through the silpad by the screw.
There is signal coming into the board. but no output. I did a quick run through on the resistors none are open. haven't checked the 5w ones yet.
How bad might this be? Is it possible it could've blown all the outputs?
None of the power transistors test shorted BC. 2sa1943 s and ktc5200 are the output transistors. I do have a few that test from the heatsink screw to collector about 2megs(this issue addressed with new mica). The others test OL.. I'll take thos out of circuit to test.
Thanks,
nosaj
Thanks,
nosaj
