Happy new year to all.
I have in a nice old Trace Elliot V4 with 4xKT88 outputs. Into an 8 ohm output it starts to clip at about 37vAC, about what I'd expect. But into 4 ohm it only puts about 25vAC before clipping. This is the case when a 4 ohm load is connected, whether the 4 or the 8 ohm winding is selected. Seems odd to me. The output waveforms are quite clean though the clipping is slightly asymmetrical at first both into 4 or 8 ohms. The amp came in because output into 4 ohms seemed a bit low. Not an OT fail mode I've come across. Any comments?
Service manual attached
Trace Elliot V4[1].pdf
