Originally posted by nosaj
View Post
Super Reverb voltage questions
Originally posted by Leo_Gnardo View PostAt what distortion level are you measuring output wattage? Practically every instrument amp will yield disappointing results measured at clip or some other low distortion level, when compared to its maker's claims. Manufacturers seldom reveal the distortion factor when boasting about their amp's power level, it's typically anywhere from 5% to 20% and sometimes flat out square wave clipping. Not too many techs have a distortion % meter on the workbench, I sure don't. I could be wrong, but my "rule of thumb" is you can add 12% more power for every 5% of distortion. IOW the same amp could measure 100W or 150W, depending on whether it's just a smidge below clip, or at 20% distortion. If you're getting 60W at clip from a Super Reverb, that's fantastic & don't worry any more. Most I work on clip in the 40 to 50 watt range.
I think Leo's right. A fair test is an A/B comparison to newer versions of similar or the same speakers. A different speaker especially different speaker which is a different size can have a completely different sound characteristics altogether. Plus the efficiency may vary quite a bit.If I have a 50% chance of guessing the right answer, I guess wrong 80% of the time.
Originally posted by Richard View PostWhat does 10% distortion sound like?
Picked up one of those hi fi test CD's awhile back. One set of tracks has some peppy jazz rock, recorded with increasing amounts of distortion on each replay as they work up by factors of ten from 0.01%. Hard to tell anything's amiss even with 1%. At 10%, sounds positively cruddy like a cheap transistor AM radio. Considering hi fi manufacturers have been flogging expensive super low distortion gear for decades, it's surprising to find out how much distortion can be in a signal before it's objectionable.
With an individual instrument, continuous distortion at 10% easily noticeable. Sounds great for electric guitar. But you can have peaks well beyond 10% on note attacks, they pass by so quickly our ears fail to notice (good studio engineers may be able to detect them) and the guitar or bass (or whatever) still sounds plenty clean.This isn't the future I signed up for.
Originally posted by Richard View PostWhat does 10% distortion sound like?If I have a 50% chance of guessing the right answer, I guess wrong 80% of the time.
Those old Utah speakers are definitely a weak point. Better speakers or more speakers are the two easiest ways to make more loudness for a given amp. My Twin from the same era came with a pair of speakers that not only had poor sensitivity, they also probably only had a power rating of 50W each. Not nearly enough for a "135 watt" amp. Sure enough when I reconed them the old voice coils had a number of discolored spots where the wire had nearly shorted. I replaced those speakers with a pair of Eminence Swamp Thangs - very high sensitivity speakers - and the loudness increased dramatically. Before you couldn't stand in the same room, now you can't stand in the same county.
The downside with a Super, of course, is you have to replace (up to) 4 speakers.
Originally posted by potatofarmer View PostThose old Utah speakers are definitely a weak point. Better speakers or more speakers are the two easiest ways to make more loudness for a given amp. My Twin from the same era came with a pair of speakers that not only had poor sensitivity, they also probably only had a power rating of 50W each. Not nearly enough for a "135 watt" amp. Sure enough when I reconed them the old voice coils had a number of discolored spots where the wire had nearly shorted. I replaced those speakers with a pair of Eminence Swamp Thangs - very high sensitivity speakers - and the loudness increased dramatically. Before you couldn't stand in the same room, now you can't stand in the same county.
Thanks,
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
Originally posted by SoulFetish View PostCome on, wake 'em up. What's the worst that could happenThis isn't the future I signed up for.
Originally posted by Leo_Gnardo View PostThey'll want to be rock guitarists when they grow up. And you'll have the unfortunate task of letting them know they can do one or the other but not both.
Ladies and Gentlemen..... LEO_GNARDO!!! {A THUNDEROUS APPLAUSE}
In mid season form. That's what I like to see.If I have a 50% chance of guessing the right answer, I guess wrong 80% of the time.
Thanks,\
Originally posted by SoulFetish View PostHa! Ladies and Gentlemen..... LEO_GNARDO!!! {A THUNDEROUS APPLAUSE}
Tip your waiters don't forget, and I recommend the chicken tonight, chef's special, it's rubbery.
