Hi.
So I've actually come to this forum because I found another thread here that mentioned what seemed to be a similar topic from years ago. I've tried my best to use the information there and now I want to formally reach out for help.
What I have is a Fender Bassman 200 Solid State Combo amp that a friend owns. I told him I would look at it because it wouldn't turn on. I found the mains fuse blown and replaced it and it came on and worked. I played for 15-20 minutes and then, all of a sudden, a high-pitched squeal came from the amp and it powered itself off. Checked the fuse and it is blown again.
So, I started googling and found the thread here. Quick (lazy) troubleshooting and I have tried to determine if the power transistors are bad. I did not remove them from the circuit (is that necessary?) while taking readings but I think they are fine. I can post my readings if you like. After that, I built a light bulb limiter and powered the amp on with everything as normal and the light bulb is super bright (short in the amp, right?).
I've read a lot about these boards being poorly made and that the solder traces could be poor. How do I go about finding bad traces? Continuity I assume. I've attempted to attach the schematic. Hope that worked...
I don't have an o-scope but I might be able to get my hands on one. But if that could be precluded with someone's wisdom, please throw it my way. Any help would be extremely appreciated.
fender_bassman_200.pdf
