Problems like an unwanted current drain will almost never be in the preamp signal chain. Which is what you are talking about rewiring. Probably moot since the voltages you report don't seem to correspond to a fault in the circuit drawing current. HV will usually be dragged down a lot more in when that happens.
Please comply with post 41 above, and one more thing...
If you pull all the tubes from the amp and take voltage readings at the rectifier output with the amp in standby. Then with the standby switch in play mode at each B+ node.
