I saw another post on this sound. The thread ended without any kind of diagnosis. It sounds like a bad speaker, but this is a head and my speakers are good.
Here's a schematic http://bmamps.com/Schematics/Peavey/...tx-sch+pcb.pdf
Preamp out signal is fine.
Into power amp sound terrible.
Line Out sounds terrible.
Using my signal tracer signal is good up to the power amp in 3.3k R166. At the junction of the cap C66 and that resistor there is very little signal. Then at U9B pin 7 it is that trashy sound.
+/-15v are there at pins 4/8. No DC offset on pin7.
I replaced the cap C66 and U9, still trashy. Here's what I've confirmed:
CR47/48 test good and there is 0v at their junction.
All components around U9 test good.
U9 pins 3/5 are grounded.
CR39 anode 1.8v
CR42 anode 1.2v
CR34/46 1.08v
Q7/9 Vb is 550mv
The power tubes are drawing 7ma per PAIR. I read this is normal and these run conservatively in this grounded grid arrangement.
+15v on all 6L6 grids
Continuity from all pins of U9 to surrounding components is good.
I'm baffled at this point.
CR39 anode 1.8v
CR42 anode 1.2v
CR34/46 1.08v
Q7/9 Vb is 550mv
