Amp came in with a blown PT. Replaced it, amp works, but tubes are redplating and bias is -2v. Pulled power tubes, still -2v. Checked continuity of supply and bias diode. All good. Replaced the bias filter cap with no change.
This amp has something odd going on with the schematic, typical for boogie and likely to be incorrect. The phase inverter cathode connects to the bias supply via a 15k resistor. I see NO CATHODE RESISTOR in the schematic. It just say E on the cathode, and E is also the end of that 15k from the bias supply. Very weird. I get theoretically why they do it, for more PI headroom, but still just...different.
When I have the PI tube installed, the bias is -2v. If I pull it the bias very slowly over a couple minutes creeps up to about -8v at the EL84 grids. Still not right.
I've now replaced the diode, and lifted the anode and clipped in a new filter cap. The only load on the supply is the filter cap... Still super low at -8v.
The schematic says it should be -160 at that point.
I'm really losing my patience with Mesa Boogie. The last 3 I've had in have been an absolute nightmare to repair.
Please let me know if anyone needs the schematic. It's unavailable online.
![Confused](https://music-electronics-forum.com/core/images/smilies/confused.png)
