I just repaired a Fender Blues Jr, which had intermittent static noise...noise that would get significantly louder as the reverb pot was turned up. C23 in the reverb circuit was leaking electrolyte, so I replaced it...and I swapped out the TL072 IC while I had the PCB out, put in a socket for the IC as well. I couldn't find a .47uF/100V electrolytic cap locally, so I put in a mylar cap of correct value instead. It seems to be working normally...is there any problem with not using the electrolytic cap? Thanks for your input.
Capacitor question
Originally posted by Leo_Gnardo View PostNo problem at all. IMHO it's better quality than electrolytic, at least it will never leak spuzz (electrolyte) as another cap in that amp already has.Experience is something you get, just after you really needed it.
Originally posted by nickb View Post"spuzz!" you've invented a new word. I like it
In any case, beware that capacitor spuzz/schmeg, it's generally sodium hydroxide plus other mystery chemicals, none of 'em good for ya. And corrosive besides.This isn't the future I signed up for.
And be careful how and where you use the word "Spuzz."
Reference the Urban dictionary definition at Urban Dictionary: spuzz
Same goes for "spooge." And probably every other word we use to describe cap goo. "Electrolyte" sounds too much like "what plants crave."
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
Originally posted by Tom Phillips View PostAnd be careful how and where you use the word "Spuzz."
Besides, it lends itself to colorful and amusing portmanteau usages. "When I looked in that old Fender's doghouse, it was spuzz-o-rama!" You shoulda seen that cap turn into a spuzzrocket after I hooked it up backwards!
Besides, UD seems to concentrate on those kind of definitions. When did you ever see anything technical in there?
While we're at it, there's a similar old tech word that was used apparently decades before I started looking inside chassis: spudge/spudging. As in "this tool is useful in spudging." Apparently it means adding extra component leads to an already soldered connection. For instance on a tie strip, when you melt the solder, poke a hole thru it so the new lead can be placed. Find that one in your UD. Or anywhere else. I got my fave spudging tool, how about you?This isn't the future I signed up for.
I also have a ziploc bag full of spudgers. I used them to replace the screen on my Kindle. Spudgers come in metal and a variety of different floors and shades of plastic... they're used for prying apart tight spaces without marring the surfaces of the components.
Well... UD has "Balls to the wall" basically defined correctly. I remember a female coworker acting offended, or at least surprised, when I used the expression in a status meeting ~30 years ago. Reference Urban Dictionary: balls to the wall
I first became aware of UD when travelling through rural Ohio and passed Fangboner Road
Apparently, Urban Dictionary is crowdsourced and accepts odd, unreasoned, and otherwise juvenile entries. The definitions at UD don't even make sense. It's a shame to take a colorful and potentially interesting term and reduce it to such rubbish. It clearly has nothing to do with vampires. sigh.If it still won't get loud enough, it's probably broken. - Steve Conner
Originally posted by Tom Phillips View PostWell... UD has "Balls to the wall" basically defined correctly. I remember a female coworker acting offended, or at least surprised, when I used the expression in a status meeting ~30 years ago.
Well I guess we solved the OP's problem awhile ago, on to better things. Got a '70 Major here needs a new kit of KT88's.This isn't the future I signed up for.
I had a female office manager not speak to me for a year once because I said she was being "anal" about one of my invoices. I finally aske her what her issue was? She said I had called her an asshole. I told her it was a fuedian term for being over meticulous to detail. Then she wouldn't talk to me because I had insinuated she was stupid evidently. Sometimes you just can't get past certain phrases.
Originally posted by olddawg View PostI had a female office manager not speak to me for a year once because I said she was being "anal" about one of my invoices. I finally aske her what her issue was? She said I had called her an asshole. I told her it was a fuedian term for being over meticulous to detail. Then she wouldn't talk to me because I had insinuated she was stupid evidently. Sometimes you just can't get past certain phrases.If it still won't get loud enough, it's probably broken. - Steve Conner
