Here are the schematics:
No Reverb...Reverb pre-send sig is present on grids of V3 but not the plates, unless I unplug Conn 2 (which goes to Conn 1 on the power amp Board)...then I see signal on V3 plates. Plate voltage is found all the way from the power supply through R7, through the primary of the reverb drive tranny to the plates of V3, but no signal. Something is loading down the signal (I'm running 1khz through the amp) but not the HV to the tube plates...
Any ideas???
I really am stumped on this one. Hopefully it's not the driver tranny as these are no longer available. It seems fine reading DC resistance through each winding and the primary and secondary windings are not shorted.
Thanks for any insights...
Any ideas???
