Hey Guys,
Hoping anyone can give some insight on this, if it's a common failure or if any one has seen it before, I know Enzo is on here and he knows all so hoping I can get some guidance.![Smile](https://music-electronics-forum.com/core/images/smilies/smile.png)
Quick background, amateur at this stuff, I think it's fun to pick up broken tube amps and fix them. I would love to learn everything there is to know but I'm not at that level yet. I've fixed a handful, less than 10. I know enough for safety, but my troubleshooting practices are limited, most problems have been visual or obvious so far.
Grabbed a BV-120H for cheapp, I know there's a lot of bad talk on this series but for 70 bucks with 8 new tubes you can't go wrong.
Low and behold I get NOTHING with power up. No indicator light, nothing reaching the tubes, basically dead. The 5a slow fuse right in front of the power is good, the 10 amp is good, there's 4 .25 amp fuses, they all test good although one looks a bit bronze, is it possible that one of these .25 amp fuses would cause nothing to work? Seems a bit far down the electrical path.
I also see other pics on the internet where I see 2 blue wires coming from the OT but mine only seems to have 1, from what I read I'm pretty sure that's only used for wiring to something other than 110 but I'm not 100%, I don't know if this one wire could be the cause.
Visually this thing seems really clean, nothing looks burnt or out of place.
It's just dead and I'm not 100% on where I should be looking but I want to figure it out.
Anyway, best advice on how to start trouble shooting this issue? What/where should I be using my meter to follow and find this issue? I'm really into this stuff and passionate about learning, and would appreciate any help.
Attached is a crappy picture pointing out where I'm not seeing the blue wire since I'm not around it atm. Will update with better later.
Any insight on this? Is it a common issue with the older bvs? I'm hoping/thinking it's an easy fix, this thing looks great inside to my amateur self at least.
![Click image for larger version
Name: Screen Shot 2017-03-06 at 10.05.16 AM.jpg
