Hi folks. I have a 1962 Fender 6G11. Layout and schematic below. A previous owner had converted it to SS diode Rectification. I am changing it back. It needed a proper spec transformer again.
I ordered a new Classictone 40-18041. The wiring diagram for it, is also attached. I have a couple of questions. I am not 100% sure on the wiring so I thought I would ask:
See Classictone PT wiring diagram: What is the orange wire on the primary side for? Other amp uses?
I assume Red/Green is a bias tap, not used in the 6G11?
This Classictone transformer has a centre tap off the secondaries, red/yellow. Correct? Same is the original, also red/yellow shown on the layout? Correct?
This Classictone PT has a center tap for the heaters, so I do not need a artificial, dual resistor center tap off the heaters, correct?
Last question: The Classictone PT diagram show 650V of the secondary side, just the one red wire. I assume that is split to 325V AC per red wire headed to the rectifier. Correct?
Thanks very much.
http://www.ampwares.com/schematics/vibrolux_6g11.pdf
http://www.davidsonamp.com/sf/images...6g11layout.gif
http://www.classictone.net/40-18041.pdf
Thanks very much.
