I have 2 of these amps here that do not passing signal thru the 300 watt side of amp. Is anyone familiar with these amps?
This is what is happening, when plugged into the 100 watt speaker jack I'm getting sound.
When plugging into the 300 watt jacks there IS the pop sound at turn on out of the speaker as if the power amp is working but no signal passes from input.
Since there is a pop sound when power on am I safe to assume the power amp section is working and the fault is somewhere in the pre amp?
When plugging into the return there is no sound, nor is there sound when jumping the pre amp out of the send to another amp.
The effects send and return work normally when using the 100 watt output.
Does anyone have an idea what is going on here?
