Dean Markley CD30 on the bench, nasty distortion at output, but not from preamp. Using sine wave and o-scope, I can see clean signal at pins 5 of the power tubes, but signal at output jack is badly distorted and jumpy. Not a loose connection.
Testing DC from OT primary CT to each plate, I expect a few volts, but I'm seeing varying voltages, from ~100mV to 4vDC.
Any other tests I can use to rule out or in the OT?
