Please see attached info for a Fender style reverb transformer. Impedance values are shown.
If I run a DMM set to ohms from Blue to Red wires, will the DMM show about 25K ohm resistance value?
Measuring green to black approximately an 8 ohm resistance value? Just wondering if this a quick easy way to test a reverb transformer?
I am suspect this is not the case. Do I need to run a signal through the circuit and scope it before and after the transformer?
Reverb on a 1972 Deluxe Reverb is not working. V3 & V4 pin voltages test good. Hum increases as reverb pot it turned up. Reverb circuit resistors test within spec. Cathode caps
have been changed by someone, unsure when. Suspect within 10 years.
Cleaned all RCA jacks. Swapped in known good reverb tank, as well as good RCA jacks. No improvement. Suspecting transformer.
Thanks, Keith
http://www.classictone.net/40-18034.pdf
Thanks, Keith
