Hello,
I have a head scratcher. A Fender Showman AA763, has a very high bias (200+ mA!) on only one pair of power tubes and it will often pop fuses when taken off standby. I've tried all the obvious things like checking for opens, shorts, failing caps in the bias supply, trying a new quad of tubes, checking the phase inverter, etc. This led me to disconnect the negative feedback and swap the primary leads (blue, brown) on the output transformer. The problem traveled with the leads to the other pair--so I tried a new output transformer. However, the problem still persists. So I'm at a loss.
When using a lightbulb limiter the amp fires up and the disparity in bias current almost vanishes between the two pairs. Therefore the lower power seems to be masking symptoms. The bulb remains lit, however, indicating a possible short that I've yet to find.
My question is... where else should I look? The PT and choke should not affect only one side of the push-pull tube set--and it certainly shouldn't travel with the primary leads.
One additional piece of info: there is an audible hum coming from the transformers when the amp is powered on but in standby. I can reduce the severity of the hum by putting my finger on any transformer and pushing down slightly. I've heard transformer hum like this before on other amps, but figured I'd provide this additional information since the hum seemed unusually loud.
Thanks in advance.
Omar
Thanks in advance.
Omar
