Hello
I've been a long time reader and now I finally decided to finally ask some questions directly!
A few days ago, I bought a very nice Traynor YBA1 Bass master amplifier with 2 X 15'' cabinet. I've been looking for a more powerful amp than my little Laney Cub 12 (with a Celestion Greenback) and this thing is definitely more powerful... Frighteningly so actually! So I've ordered a master volume kit (and a bias adjustment kit) from London Power website just to be able to get some crunch from it, because it stays very clean way above my listening pain threshold levels.
So while I'm waiting for those to arrive, I would like to fix (or at least try) a buzzing power transformer. I didn't notice it at the seller's house, or maybe it wasn't there, I'm not sure. I transported it carefully, on the passenger's seat, not in the trunk. Once home, I plugged it in and it was buzzing quite loudly, as soon as you power it up, even in the standby mode. For now it still has the good ol' two prong cord, which I will replace by a three prong counterpart first thing this week, maybe that will help. I tested the tubes just to make sure and both 3 12AX7s and 2 EL34s tested strong and with no shorts. I will remove the chassis tonight and will check if I can tighten the transformer's bolts. I will also take some pictures for your viewing please
Is there anything else I might want to look for? Loose filtering capacitors connections?
I'm a careful novice basically: I know how to do some clean soldering and how to discharge caps before starting poking around a tube amp, but I do not have sufficient theoretical knowledge to diagnosis everything by myself... despite reading a lot of books on the matter... so maybe starting to do actual debugging will help
Thank you all very much in advance!
