I have one of these amps without the footswitch.
Thanks to this thread: http://music-electronics-forum.com/t39376/ There's a lot information there that's been very helpful.
So, if understand this correctly, the effects, reverb and tremolo in channel one and boost and clipper in the second channel,
need the foot switch in order to be activated. Is this true?
IN the 'pre - 2" PDF some one had written that to activate 'the boost and clipper connect 2 & 3 to ground'.
My switch is not labeled with numbers. Instead they use the letters for pin numbers.
The problem I'm having is determining what gets connected to ground or whatever else. Some of the pins have 20vdc on them and I'm reluctant to start randomly connecting these pins. I did try connecting to ground the ones without voltage and nothing.
How can I test this amp's effect? Is there a wiring for a pedal?
Where is the footswitch in the schematic? J3 where the tech had written in the above?
Lot questions here, sorry. Any help would be greatly appreciated
Thanks
pete
Thanks
pete
