Bandmaster AB763 low output w/ weird distortion (scope shots attached)
Originally posted by mozz View PostVoltages on all tubes ok? Ripple? How much are you driving the amp with?
Here's the voltages:
Originally posted by The Dude View Post^^^^^^ Yes. That. Check your voltages and for ripple. It looks like B+ might be "giving up the ghost". My best guess would be failing filter caps.
How about trying it at 1K instead of 440Hz. with a 100mv input signal.
Also, it appears that the amp should be run into a 4 ohm load.
http://www.thevintagesound.com/ffg/s...b763_schem.gif
Originally posted by Randall View PostI have a question. Where does the 100V on the PI cathodes come from?This isn't the future I signed up for.
I don't know how it works, but I know the LTPI just does that... No mistake or busted connection. There's a huge writeup on Randall Aiken's site about how that PI works, but it's over my meager abilities; I still don't grasp impedance and all that... But the schematic says it belongs that way!
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
Originally posted by Leo_Gnardo View PostSome disconnection between PI cathodes and ground, my best guess. Either the ground wire from circus board to ground bus has come loose or that pesky feedback node resistor (100 ohms usually) has come loose, as they do.
waspclothes,
You did an excellent job of documenting the DC voltage readings. Marking up the schematic is the best method to convey the information.
I suggest that you do the same with AC voltages with the following setup:
Connect a 4 Ohm load to the output
Set all the volume & tone controls to max.
Make sure the tremolo is off
Inject a 10mV, 1 kHz signal into the #1 input of the normal channel.
Mark the resulting AC voltages on the schematic.
Also verify that the readings down line from the pre-amps are relatively the same for each channel.
With that data, we should be able to see where things are going wrong.
If all is good up to the 6L6 grid pins then we may need to substitute in another OT. BUT FIRST - measure the 6L6 screen DC Voltage right at pin 4 of the tube sockets.
I see nothing wrong in the scope images, both PI plates are strong and clean, with jutthe top end *arely* reaching clipping, and output signal into speaker somewhat rough but nothing to write home about.
By the way, you are not using the proper load impedance either.
1) use 4 ohms load
2) rise volume until it *really* clips, signal becomes visibly squared, take mental note of the peak it reaches, both sides, then slowly lower signal until most of it goes below that peak level you just found, letting positive and negative peaks still smash against them.
A true squarewave would be 50% of the wave width (meaning 50% of the time) flat against the top limit; other 50% (width/time) against the bottom one.
Lower signal until, say, 10/15% peak widths are clamped against the limit.
Now take RMS measurement again and repeat the Math; it should have improved a lot, although I doubt it will reach 40 or 50W.
3) if you wish, play with bias voltage, vary it between, say, -40 and -50V , see if power output as defined above improves by 5 or 10W .
Couple watts gain is not worth it.
Designers in general go for maximum output power , and colder bias; musicians go for "tone" and have no clue about power (they never *measure* it, so .... ), couldnīt care less about dissipation, tube life, etc.Juan Manuel Fahey
Originally posted by J M Fahey View PostI see nothing wrong in the scope images, both PI plates are strong and clean, with jutthe top end *arely* reaching clipping, and output signal into speaker somewhat rough but nothing to write home about.
1) use 4 ohms load
