Marshall 50W JCM900 model 4500 Dual Rev comes in for a cleaning, and because "it just doesn't have what it used to have". It has a mismatched set of a big bottle GE and a skinny bottle Telsa (I think), so I sell him a new set of JJ's. Problem is, I can't get them to draw close to the proper current. With the bias pot full CCW I can only get 12.9mA on one and 13.6mA on the other, this is with no meter connected to pin 5. With a meter connected to pin 5 I get 2mA more on each tube.
I don't get it. I know it's not the new tubes, because I found the same thing with the originals. I must admit, I don't totally get how this bias circuit is working, but I do know it is delivering a few volts more negative than the drawing calls for at the set point. And I don't know if this is related, but it makes a "fwooOOP" sound when the power switch is shut off, regardless of the standby.
Here are my readings, both tubes are within a volt of each other:
pin 1: 0v (tied to pin 8)
pin 2 - 7: 6.7vac
pin 3: 465v
Pin 4: 462v
pin 5: -45
pin 8: 0v
It is interesting that the tubes pull more current with a DVM on pin 5, could this be the meter pulling the bias voltage a bit less negative?
http://www.thetubestore.com/lib/thet...-Schematic.pdf
pin 2 - 7: 6.7vac
pin 3: 465v
Pin 4: 462v
pin 5: -45
pin 8: 0v
