i have a marshall dsl 2000 100 watt head how do you know when you need new tubes or when the amp needs re biaes?
how do you know when tubes need changed
Oh you could check the bias once in a while. But mostly we set it when they are new, and pretty much let it be.
If the tubes are showing signs of failing - pops and crackles, flashing, or other things - then get rid of them NOW before they damage something.
Otherwise, you know when to change them the same way you know when to change strings - when the tone has gone away. They will still function long after their tone has gone lifeless.
I'm in Lansing, where are you?Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostOh you could check the bias once in a while. But mostly we set it when they are new, and pretty much let it be.
Originally posted by Enzo View PostIf the tubes are showing signs of failing - pops and crackles, flashing, or other things - then get rid of them NOW before they damage something.
I remember the first time I saw a flashing tube. I had dumpster dived an old Silvertone Twin Twelve head, and it had two RCA Blackplate 6L6 in it. I was in hog heaven. I even thought it was cool to see the tubes flash blue every time that I strummed a chord. The Blackplates didn't last long. Sigh. The good news is that the tube didn't take anything with it when it started arcing."Stand back, I'm holding a calculator." - chinrest
thanks for the replies
Originally posted by 60 second crush View Postdo i need to replace all the tubes i take i do???"Stand back, I'm holding a calculator." - chinrest
The four large power tubes wear out just doing their jobs. That is normal, just like it is normal for your car tires to wear out after so long. SO if it is time to replace tubes, replace the set of four power tubes. The small tubes - 12AX7 type - don't really wear out. They can last for many years. Some do fail, of course, but it is not really necessary to replace the small ones when the large ones go. Unless of course one is bad, in which case replace the bad one and leave the rest.Education is what you're left with after you have forgotten what you have learned.
