Hi
I've been researching what appears to be a common issue with Hartke LH500 amps, that being the protection circuit.
The amp I have belongs to a friend. He's asked me to have a look at it as it's dropping out. The amp may or may not produce sound on start up, and if it does come 'on' on power up (after a short delay as expected) it doesn't last long. Its hit and miss whether it comes on or not. You can hear the relay actuate when it does decide to allow the output to the speakers.
Voltages to the power amp board are good on measurement.
I can tell from my limited knowledge and following the signal through the amp with my CRO that its the protection circuit causing the issue as I can see the amplified signal at R336. Having seen a video from another thread showing how to change the 'differential transistors' Q067 and Q301, and reading another thread commenting that the caps in the protection circuit C315-318 should be replaced, I've gone ahead and ordered the parts.
Not knowing much about how this bit of the circuit/board works I'd like to understand it a little more so if the daughter board is bad I can diagnose it.
The schematic is v3.8 Attached for reference
Any help gratefully received.
