Hello
This one is doing my head in.
Customer brings it in with 2 blown fuses and stated that he has changed the fuses they blew straight away
srs1501_AMP_board.pdf
Checked it out Loads of s/c and o/c parts changed
I have changed all of the transistors/fets on the heatsink
Q19/Q14/Q17/Q12/Q15/Q2/Q4 and U1 ( changed to be sure )
D26 to D29
R17/R16/R31/R32/R22
There was a couple of burnt out tracks. All repaired with point to point wired
All the above were blown and replaced with the correct part and part no
Went around the board with meter lifting and checking all resistor/diodes etc
At switch on via Lamp limiter no excess current draw
All voltages measured with lamp limiter in use
On speaker output -19v
15v +/- are correct
25v +/- are correct but at point of R13 to D6 1.8v +
D16-D15 LED's are ok and on
U1 pin 1 and 2 have -19v
U1 pin 15v+
On page 2 of map they show psu, #1 #2 measuring across these points 19v
Measuring across C10 129v
This one is trying my experience and skill
I have read what i can from this forum
Im struggling to get my pc to correctly link up the schematic
Link below will take you too the download site
https://www.elektrotanya.com/mackie_.../download.html
any advice
BBB
D26 to D29
R17/R16/R31/R32/R22
15v +/- are correct
U1 pin 15v+
any advice
BBB
