After powering up my build for the first time and checking my power supply and biasing for stability etc, I hooked it up to a speaker load and turned it on with the input jack shorted and volumes down. I noticed quite a bit of noise output from the amplifier. Way too much noise for me and much of it is 120Hz supply ripple coupling through. Pulling the V1 and V2 tubes had no audible effect on the noise at all. I was worried that it was my driver tube, which has it's own isolated powers supply and dedicated winding. But, after pulling the PI, the driver and output tubes are dead quiet.
Without having put a scope on the rail, the simulations indicate that it should be well filtered at the PI filter capacitor. There is a switch to activate negative feedback, but that is a howling mess. But with this much noise before even adding global feedback, and it's potential for instability, I'm not surprised at all that it's oscillating.
Any thoughts as to what maybe causing the noise to couple through the PI stage? I'll post the PI schematic in a little bit.
