HI,
This amp came to me blowing the mains fuse. Problem was one of the flyback diodes was shorted. I replaced both with RGP02-20E which is a 2kV/500mA diode. The amp was working properly for a month but then it blew the fuse again although at that moment it was only ON without being used. The problem is the same - one of the flyback diodes is blown again. What I did so far:
1/ Checked and resoldered all connections on the speaker board
2/ Removed and connected the speaker wires to the connectors several times
3/ Tried to clean the speaker jack contacts
4/ Installed 1 Ohm resistors to the power tubes' cathodes for easy biasing and monitoring
5/ Checked the OT for resistance, inductance and shorts
Output power before clipping is ~42W. The sine wave is normal (in full power mode). Power tubes are RUBY 6L6GCMSTR. One of them has the paint more "baked" and glows more than the other however they bias within limits.
This time I intend to put 3x1N4007 in series on both sides of the OT but obviously there was a problem (and maybe it's still there) so I would appreciate your comments about what it could be.
