Hi Guys,
This is a long-running bug bear of mine that I've not been able to get to the bottom of - I'm hoping the fair folks of the forum may be able to shed some light where others haven't?
In essence, the problem is this - run any guitar amp with a beam tetrode based power section into any type of attenuator and when the amp begins to break up and reasonably heavy attenator, a harmonic buzz is produced from the bass-end notes which sounds like it's phased.
Any beam tetrode he says? Take an amp like a Komet 60 that can run EL34, 6L6, 5581, 6550 etc - play it unattenated and whilst it's likely to get me arrested due to the volume, there's no nasty artefacts in the tone
Now let's run it through a re-amp (Power Station, Two Notes) a reactive load (Rock Crusher, Radial) or a passive load (Kock loadbox or Airbrake) - the EL34s still sound awesome, but any of the beam tetrodes buzz like someone is accompanying me on a Moog Synth
So it must be the amp then? .. OK, let's try two Komet 60s side by side with 2 Power stations, swap EL34s and 6L6s between them and then swap the attenators - and follow the buzz)
So it must be the circuit then or the mismatch of the OT Primary? ..try and amp with a Primary impedance tuned to one tube type? OK, so let's put a 5E3 with an 8k Primary or a 5F6 in there - same issue
Just to the record, i've systematically ruled out speakers, cabs, cables, guitars, power supplies and even the room itself
I currently have 2 Power Stations, a Rock Crusher and an Airbrake and I could predict 100% of the time when this is going to happen and it's never heard with Pentode power tubes and always there with beam tetrodes
I've gone as far as I can with this - I've even tried to EQ it out with a graphic and tried snubber caps pre-PI and on the plates with no effect
If you look at the difference in the tube design, then this has to be something to do with secondary emissions, but I've no idea how to practically prevent it from happening?
So Gentleman, what's going on here and how do I fix it?
