Hi all,
I have an SVT 450 in for repair. All o/p transistors have bmlown as well as their ballast resistors and the 47Ohm at their gates. D18 (13V Zener) has also been replaced. The amp outputs a sine wave now but I can't set the bias according to the schematic the pot is ok): it only goes from 4.5 to 5.6V accross the 47Ohm/5w resistors. Q3 was also burnt and I have replaced Q5, Q6 and Q8 so far.
Also, with no load, the output appears "doubled" on the scope, as if it was modulated by a very high frequency (a bit like with a class D amp). i doubt this is normal. With a load, there is no such modulation.
Any ideas as to what could still be at fault here?
ampeg SVT450.pdf
ampeg SVT450.pdf
