Amp came in with no sound. Opened up and found that the low v supply resistor was heating up so much as to melt the solder joint completely... disconnecting the supply and causing a "no sound" fault.
I've replaced the dropper resistor with a 350 10w and it is still overheating, and the +15v supply is at +14v and slowly decreases after turn-on. -15v supply is -16v.
I've replaced all 4 low v supply caps and the +15v zener. Still same symptoms. I've scanned the schematic for the most likely culprit and nothing jumps out.
The amount of Boogies I've worked on this year that I've spent 10-20 hrs on and had to give up is already about 3. This is getting off to a bad start already. The former 3 repairs I had to diagnose as "conductive pcb."
Anyone dealing with this with Mesa Boogie? To add to it, it's not easy or fast simply getting to the solder side of the pcb. So after each "repair" it all has to be rewired again.
Any suggestions on this specific repair appreciated. I'm "this" close to not going any further wasting my time.
