There should not be any voltage drop across the 1 meg plus 50k into the grid. DO NOT measure voltages to ground, your meter impedance will addle the readings. I can believe -41.9v, but measure voltage from that -41 point directly to the grid pin. You have 3.7v across the cathode resistors, and I expect about that same thing if you measure directly cathode to grid pins on the socket.
Almost 50v bias on an EL84?
