Hi, folks, last year I bought a 90's 8080 amp, and it worked fine, but last months it had a intermitent fail, suddenly went low volume and sounded distorted. I kept using it because the amp started sounding well again, and failure wasn't that often, but now it sounds distorted all the time, in both channels.
I've been reading posts about issues with this amps and I started measuring some things, but I'm getting a little lost with this.
Today I tried all +15 and -15 V lines and readings were really close to 15, but never exact. Positive line changes a little when I plug the guitar, increases some, but sometimes is below 15, I don't know if I'm measuring wrong, the tester is bad or if this is normal, really.
I've also checked that transistors are getting around +42 and -42 at the center leg, but I don't know if they are working well. All three of them must be isolated from the heatsink, right?
How you'd start repairing it?
