This amp looks like it has had a ton of work done in the past. This amp has what I think is a 120 hz hum.
I noticed the 4700uf 50V cap starting to fizzle/spew smoke on its plus side. This cap is adjacent to the huge 7800uf 100V cap.
I measured 78 VDC on the positive side of the 4700uf cap. which is rated at 50V. On the board someone wrote 2000uf 50V (perhaps that was the original value of this cap).
Guessing I have an issue before this cap since the voltage is too high.
I have attached images and what I have for a schematic. Having a hard time finding this cap in question on the schematic. Would like to back trace and check components and try to figure out why voltage is too high.
Thank you!
![Click image for larger version
Acoustic470PA (1).pdf
Thank you!
