Originally posted by Tom Phillips
View Post
Unequal resistance on output transformer primary
Originally posted by Tom Phillips View PostCan you post a schematic of the Beltone AP-22 amp you are working on? You went down the "bad OT" path right from the start but now the low drive voltage has my attention as a suspect clue to the problem of "very low output" that you reported in your first post.
Originally posted by Mick Bailey View PostI use the 'toner transfer' method. I print using an Epson AL-C900 Laser onto the cheapest inkjet photo paper and iron this onto the bare PCB. Soak the backing off then etch using 9% H2O2 + HCL. It clears the copper in under 90 seconds. Drill, then clean off the 'resist' with acetone. Or, wire wool + detergent.
You have to make sure the photo paper is heat-resistant. I test new batches of paper by cutting off a strip and testing it with a clothes iron set at the hottest (cotton/no steam). If it sticks then it's no good.
I've done elaborate double-sided boards and complete amps using this method.If I have a 50% chance of guessing the right answer, I guess wrong 80% of the time.
So this is indeed very strange. The one side on the OT is stable at 157 ohms. Nothing wrong with my DMM, for that matter there is nothing wrong with both of my meters or the batteries in them. The problematic side shows 340 ohms as of this writing. So having checked the resistance at various times it has been 420 ohms, 207 ohms, 320 ohms and now 340. Also strange is the fact that if I sit and watch the meter for a few minutes I see that the reading jumps around constantly on that side. It bounces around within a few tenths of an ohm, up and down constantly but seems to trend downwards by a couple of ohms per minute or so at times and then upwards again at other times. Something is definitely wonky with this thing. Any other insight would be appreciated.
It seems to act like there is a bad splice in the problematic winding inside the transformer. Have you removed the end bells to look around a bit? Does it act differently if you vibrate /heat /cool the transformer or pull on the wire lead of the problematic side?Last edited by Tom Phillips; 07-10-2017, 11:09 PM.
Agree^^^
Look inside to see if the solder connection between the end of the winding and the insulated wire that comes outside is loose.Education is what you're left with after you have forgotten what you have learned.
Hey guys, can you help source an ideal replacement for the transformer? Again, the amp has a pair of EL84 output tubes. Same output tubes as a Blues Junior. Would this one do the trick?
https://www.tubesandmore.com/product...es-junior-15-w
Originally posted by bobloblaws View PostHey guys, can you help source an ideal replacement for the transformer? Again, the amp has a pair of EL84 output tubes. Same output tubes as a Blues Junior. Would this one do the trick?
This would be a better option as you have a choice of 4 or 8 ohm taps. Not much more and they're transformers sound good too.
Fender Princeton Push Pull Style Output Transformer, 125A10B & 022913
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
Originally posted by Tom Phillips View PostI'm curious to know if you looked under the end bell as suggested in the recent posts? Any comment on that?
Originally posted by bobloblawsThanks, nosaj. According to this TDPRI thread (linked below) it is not an official schematic. I read somewhere else that the schematic is for a different brand but is nearly identical. In fact I have identified a couple of things different between the schematic and the amp itself, the wiring coming off of the PT and filter caps is different (for example in the amp there are 2 - 20uF filter caps as opposed to 3 on the schematic) and there is an additional 3uF electrolytic cap in the amp that appears to be original factory installed. So I don't think the 4 ohm designation on the schematic can be taken as gospel despite the fact that the OT appears to be original. I admit that I didn't even notice that marking on the schematic and assumed the output was probably 8 ohm. Is there some way to take a measurement to determine what the OT is looking for?
Voltage Troubleshooting | Telecaster Guitar Forum
Originally posted by nosaj View Postno that is an 8ohm tap. This schematic you used in another post shows a 4 ohm output. Now if your speakers at 8 ohm then it would be ok.[ATTACH=CONFIG]44114[/ATTACH]
nosaj
Originally posted by bobloblaws View PostThanks, nosaj. According to this TDPRI thread (linked below) it is not an official schematic. I read somewhere else that the schematic is for a different brand but is nearly identical. In fact I have identified a couple of things different between the schematic and the amp itself, the wiring coming off of the PT and filter caps is different (for example in the amp there are 2 - 20uF filter caps as opposed to 3 on the schematic) and there is an additional 3uF electrolytic cap in the amp that appears to be original factory installed. So I don't think the 4 ohm designation on the schematic can be taken as gospel despite the fact that the OT appears to be original. I admit that I didn't even notice that marking on the schematic and assumed the output was probably 8 ohm. Is there some way to take a measurement to determine what the OT is looking for?
