gallien krueger 700rb bias issue
  • gallien krueger 700rb bias issue
    Hi,I have a problem with g/k 700rb(not Mk2)
    Symptom:Adjust bias 5mv at P2, and about 5 minutes later this voltage decrease step by step.
    After more 5 minute this voltage 0.5mv.
    Voltages at TPs are looks like normal.(Reference to schematic from web.)
    I changed almost all transistors in power amp circuit except Q2.
    Is there anyone had such a experience like this?
    Regards.
    On any amp, set it more or less, and watch it, then recalibrate after maybe 20 minutes. After the amp has fully warmed up. Bias normally adjusts to temperature.
      Thank you for reply.
      But 20 minutes later bias adjust pot(R23) does not work at all even if I turn it full clock wise.
      I changed bias adjust pot but same as before.
        Try some freeze spray while monitoring bias current. You might be able to narrow down which parts is taking a dump.
          First guess is the bias transistor itself.
            Is this the correct schematic?
            http://music-electronics-forum.com/a...ueger700rb.pdf
              I changed bias transistor(Q23),but same as before.
              Q23's vbe is 0.5v〜0.6v.
              Yes,it is the schematic of my 700rb's.
              Regards.
                See post #4.
                Get out the freeze spray and cool areas until you find one that affects this.
