Only joking, but...
Not posted for about 5 years (on the old ampage), so hi everyone I've not been in touch with - how are you all? (Moved towns, stopped playing so much, any of the "old school" still around?)
Got a Fender Stage 160 DSP on the bench (don't ask). Never knew transistor amps were so complex. Came in with a blown fuse. I replaced the fuse, switched on, and the driver transistor for half the main power transistors caught fire and then exploded. Its opposite number smoked but didn't explode. At the same time both speakers moved out to one end of their travel with quite a bit of (mains?) hum. Biasing resistors for the driver transistor and the grid resistors (I guess that's base resistors) for half the power transistors also turned brown and smoked a bit.
My assistant, a German Shepherd cross with a keen interest in electronics, was quite impressed. I don't let him help with valve amps, but with lower voltages he was allowed to witness the demise of the Fender.
So far I have replaced all of the decoupling caps for these transistors (both sides), both transistors, and the filter caps for the circuit they are in. When I turn the amp on it no longer catches fire, but the speakers still push out to full travel with a load of mains hum.
I assume there's some DC getting into the speaker circuit (are these amps Class B or something, it's diode city!) so it's likely to be a cap problem especially given the high level of low frequency hum. So what do I do next. (And don't say "pull the power tubes and check B+ for ripple because I'm cursing the invention of semiconductors at the moment")
Any help greatly appreciated. Can email a schematic if that's any use.
TIA
Liam
TIA
Liam
