Did this issue get resolved? Been following to see what the actual problem is.
Marshall JCM 25/50 Low Volume & Distorted
JCM25 50 Jubilee.pdf
I got a chance to get back to the amp and what I did was take all of the AC measurements on all the 12AX7 tubes with a 1kMHz 100MA signal with the volume knobs at max. Power tubes removed. The second plate of V2 is putting out 40VAC. Does that seem high to anyone?
I attached an updated tube measurement chart with the AC voltages indicated in red font.
Possibly due to the power tubes being removed / is raising the preamp voltage, has there been any other changes since the last voltage chart?
edit: ok went back and reviewed first voltage chart so voltages are the same looks to me so that said
what has changed?
So what does it sound like now?Last edited by dstrat; 08-17-2017, 06:03 AM.
