WOW. Am I confused! This JCM 800 Lead came in for a long time noisy hum. Attempts to remedy it have been made in the past.
While checking it out I discovered plugging a dummy plug in the FX Return caused it too go ballastic. The hum got much louder. I measure it as 60Hz. The 3 wire bundle from V4A to the board were very touch sensitive and noisy when probed or moved. I removed C26 on V4A grid, no change. Grounding V4A grid stops the noise. Tried a different tube, no change. The Pl,Gd,Ck wire bundle wraps around the reverb transformer, so I disconnected the HV to it, no change. With V4 removed I see 1.5K ohms from cathode pin to ground, 1M ohms from grid pin to ground, and 100K ohms from plate pin to R58 (10K 1 W).
I swapped out V5, no change. I removed C25 at the grid of V5 (second page left) to isolate stages, and the noise stopped. With the V4 stage isolated, I see noise on it's plate and with my scope I can see that the wire bundle is still sensitive. I see the noise on the pin side of the plate resistor, but not the feed side, and Y goes to nothing, so where could this noise be coming from? I'm at a loss.
I also notice that V4 socket has been replaced, so it looks like someone else had a shot at this at some point. I looked it over real close, and it LOOKS okay. Oh, and the filter caps have been replaced as an attempt to cure this as well.
Marshall-JCM800-Splitch-50W-2205-Schematic.pdf
