So, after selling a GK BL600 to a friend, he informs me that the fan isn't working. I search the web, find that fan failure is common, order and install new fan. I turn on amp, during start-up (brief "protect" mode) the fan cycles and shuts off as soon as status light goes green.
Knowing it's a temp controlled fan, I can only assume this might be normal behavior (I have very little experience with the operation of this amp).
i step away to grab my heat gun to warm up the insides to make the fan cycle and as I return with the heat gun (20 seconds or so) I see a litttle whisp of smoke come from the fan. I power off the amp immediately, lean over and smell the distinct odor of a burnt component and the motor is hot to the touch.
I test the supply to the fan and see it as 58 VDC. This is a 24VDC fan, won't that always let the smoke out?
What gives?
EDIT: added schematic 7/27/17 9:09 CST
What gives?
