Hi. I picked up a project GA-40t with a bad power transformer. I have a salvaged power transformer that I patched in. It is physically larger, but the HV winding somewhat smaller...getting 365VDC B+ where schematic expects around 425. The amp works...sounds OK. My transformer also has another winding that puts out 14 v p-p and is unneeded on this amp. Could/should I series-connect that winding with the HV winding to get a few more volts on the B+?
What sort of artifacts will i generate on the amp if I leave the B+ low?
To spec a new Hammond 200 series transformer, do i just look for a proportionally larger P-P output using the 365/425 ratio?
Thanks.
Thanks.
