So the tweeter sounds like garbage if the amp is turned up...even to a lowish gig level volume. There is no crossover in here. So first, I tried a new sub tweeter. No change. Then I inserted my bench crossover. No change. Disconnecting the tweeter, woofer sounds mostly good. If pushed it does begin to have a similar, yet darker, issue. So...I'm thinking it's the amp not the tweeter.
Suggestions? I will check the output transistor bias. And report back with some realworld numbers on Vac and wattage at breakup. It really happens on transients...when the string is picked. Now realizing I should've taken more measurements before posting.
