Peavey XXL 60hz hum
My crazy ideas and story.
I have an XXL combo chassis (unit 1) in good working order that I was going to build a head cabinet for. Last week I found a non working XXL head (unit 2) with burnt components on the amp board.
The combo chassis (unit 1) does not fit into the head cabinet so I decided to try swapping the burnt out amp board in unit 2 with the working board from the combo chassis (unit 1).
I ohm'd the PT and OT from both units and they had identical readings.
After getting the good amp board installed into unit 2, and all volumes at zero, I slowly brought up the voltage on the variac and immediately (at low voltage) was hearing a loud 60 hz hum which would get louder as the voltage increases. I quickly backed off on the variac.
There were a lot of missing screws connecting the back panel and OT to the rest of the chassis, I did replace most but not all (mentioning this in case there is a ground problem).
Before I abandon this idea and go back to my original plan (build a head cab for the combo chassis) I thought I would check on here for ideas on what the problem could be.
I have attached pics of the original burnt out board (in unit 2) in case that is a clue to other potential problems.
Thank you!
Thank you!
