Hi all, I'm looking for advice on this impedance selection switch. Complaint reported was weak output when selecting 16ohms on the impedance switch and using 16-ohm cabinet. I am a neophyte in tube amps and I have not been able to figure out these wires. It has the flat rotating selector switch, not the plug, not the domed selector.
![Click image for larger version
Name: output selector.png
The OT was previously replaced with a Hammond, so the wire colors are different from the schematic and other pictures I've found; fortunately it is labeled:
Name: replacement transformer.png
The Orange 8-ohm wire, it is connected to the terminal which is jumpered to the opposite side; this is where the black output wire is attached.
There is one terminal to the right of the orange that has old solder on it. I am _suspecting_ this is where orange used to be, before it became the new black ...
Wiring:
Name: bad output selector wiring.JPG
As you know it is nigh impossible to use the multimeter to suss out the switch due to the transformer carrying the current to all the other jacks.
What does this look like, wired for 8-ohms all the time? Selecting 4 or 16 is going to be pretty hairy, isn't it? Is it a 6-8-12 ohm selector now?
Is this some JCM800 mod I haven't yet read about? The previous techs had also wired the power switch backwards so that it worked, but did not light the indicator; it seems anything is possible in here. I may have to remove the switch for closer examination, maybe it is broken and this is was a workaround? Do these switches come apart for cleaning?
Big pic of the internals, you'll notice a couple more mods I haven't tried to figure out yet: https://goo.gl/photos/NzBdihY1Ui2bVkPz6
thanks in advance for your advice!
Rick
Wiring:
Rick
![Noob](https://music-electronics-forum.com/core/images/smilies/icon_noob.gif)
