Got a silverface Pro Reverb in. Low volume and distorted. Tried my bench speaker...sounds great. Back to pro speakers...sounds great now. Hmmm... decided to check the footswitch to see if vibrato and reverb work. When I moved the footswitch from the back of the amp the amp briefly went low volume and distorted again. I then pressed the footswitch case (ground) against the speaker FRAME and found that it caused the amp to mess up!!
I checked with my fingers to see if any of the speaker leads between the cone and terminals were touching the frame. And therefore shorting the speaker... Nope.
Thoughts? Some capacitive coupling back to the reverb circuit? Maybe a parasitic oscillation from speaker to reverb circuit? It's trippy...man.
