This amp came in sounding like a blown tweeter. After subbing tweeter and speaker too... I believe this is a circuit problem.
I got out the scope and found that with a 1k sine at 200mv RMS into the input, at a certain point there is serious crossover distortion at 10.3vAC RMS output (no load). This is with the drive very low around 2.5 and master volume at noon. Maybe this is because I have no dummy load.
Thoughts? Is it typical for a cold biased power amp to sound better at low volumes? Or vice versa?
I do believe the limiter FETs are working correctly as I don't see any clipping of peaks.
