Hi,
I've got a Marshall Valvestate VS65R that I love. Unfortunately its stopped working. It powers up just fine and will output sound at very low volume if the Volume pots are turned right up, but nothing like it should.
Ive tried various things based on searches in this forum and elsewhere but have had no luck. So here I am cap in hand asking for help.
Some history;
I replaced the Valve a while back with a similar one 12AX7 and it was working fine. About two weeks ago I had the house to myself and was going to make some noise, but got nothing from the amp. I thumped it and still nothing!
I ran to google and found that there were reported problems with the large cement block resistors getting hot and causing bad solder joints and the dreaded switch fault with the jacks on the back. So I reflowed all the solder joints that looked even slightly dodgy (I tested continuity on these joints too) and tested all the jacks on the front and back. No change.
I had some spare electrolytic caps lying around and have replaced the ones in the amp no change there either.
I've tried the headphone jack and had no luck there.
So I took out the Muting gate (T16 J111) and tested without it and still no result.
Im not sure where to go next.
The best schematic I can find is this one which is hard to read (due to the original scan methinks) and not enetirely the same as my board (there are some discrepancies between my board and the schematic -probably just revisions)
marshall_vs65r_65w.pdf
I'm a shiftworker so my response may be delayed or erratic, but I am happy for any help getting my amp working again.
Also living where I do (Perth Western Australia), some parts can take months getting here, so it can take a long time for me to get results. So Id rather replace several components at once than one at a time.
Some history;
