This JBL/UREI Model 7110 Limiter/Compressor came in the shop and I kid you not, the repair ticket says in the “Work to be done” section “No Bottom (LowEnd)”, that’s it. I know this customer and he has a recording studio… oh boy! pro audio!!! I want to trade some fixing for some mixing but that’s another thing. Forget about getting a more precise description from the client, it would only make things more confusing, trust me.
The manual and schematic are easy to get and I saw it had two test points named “A” and “B” for the +-18 volt rails which power the army of op amps on the board. I figured if one side was out that might account for this elusive lack of bass compression or is that limiting, or both, I don’t know if I even understand what that means… anyway, both rails checked out good and dandy so now what’s next?
I put some sine waves on the input at 0db and I read the sine wave from the output set to 0db with a scope and yes, indeed! there’s a sine wave passing through undistorted whether the thing is powered or not. When power is applied the led displays reflect the systems condition pretty much as you would expect. If I twiddle around with the threshold, detector, attack, release and ratio I get things to happen, I get loss of output db and things like that, things that look compressor like and limiter like but a scope image of an undistorted sine wave don’t really tell me much. I don’t know if I actually have a coherent technical non subjective check for this type type of anomaly or really what I might be looking for in the first place, does anyone have a clue on this and how to diagnose a problem like this?
I know it’s closing time Friday and I won’t get back to things until Tuesday but it always seems that I get a little problem child right at the end of the work week which gives me time to gobble up my days off mulling things over.
