1969 Marshall
  • 1969 Marshall
    I have a 69 Marshall 100w on the bench for a look over. Its serial is SL/A 7335A .
    4 input / non master / EL34's
    5 , 50/50 Erie filter caps
    So, on 2 of the 50/50 filter caps towards the power section there are 2 , 2watt? resistors mounted to them , BUT , they are 47K.
    Shouldnt these be 10k ??
    Im not finding any 1959 model scems that show 47k there ?
    They should be whatever they are. The amp has gotten along with these resistors for almost 50 years. Seems pointless to decide they need changing at this point.
      These are for balance only, usually 56k, but value doesn't matter much. You're fine with 47k, just make sure they're within specs.
      http://drtube.com/schematics/marshall/1959mk2u.gif
        And don´t go any lower.
        10k resistors used as bleeders will smoke, glow dull red and burn in a couple minutes.
        Obviously that dayb they had run out of 56k and 47k was close enough.
        As Enzo says, leave as is.
          The "magic" in why some Marshalls sound different!
          They often used what they had lying around to fill orders.
            47k / 56k are also small draining a lot of current...but I just wonder now if are not choose it for this reason- draining fast with a rate to discharge to cut power grids before bias voltage goes to low when switch power off
              His resistors are not bleeders, he is referring to the dropping resistors between nodes.
                To clarify the node feeding the screens with 2 100-100 series caps usually did use 56k bleeders 1967 schematic used 32uf and do not show bleeders or balance resistors.
                correction: 100-100 series caps for screens are on the 1970 schematic.
                if they used 47k Juan most likely correct, used what they had at hand.
                  I stand corrected, Enzo had it right according to this 1969 photo.
                  Marshall Model #1959 JMP Super Lead ? Amp Archives
                    You are not talking about the same resistors
                    * Those wired *across* cap terminals (+ to - ) are bleeders, schematic value 56k, 47k is acceptable.
                    Not that large current consumption: around 5mA , and are dual purpose: equalize voltage across series capacitors and safety discharge them in a couple minutes.
                    * those separating caps , feeding different preamp stages (and phase inverter) are voltage droppers, typically 10k each, they also make an RC cell to filter ripple out.
                    They are not interchangeable, as I mentioned above 10k bleeders will overheat and burn, 56/47k droppers will drop too much, PI would still work but first preamp tubes could get as low as 90V or even less.
                      I am yet to be dissuaded that whichever resistors he sees, he need not change them to different values from the ones that have worked for decades.
                        ok thanks
                          another oddity....there are 2 large metal caps , on the end of the board , power section. They dont appear to be polarized
                          they are labeled 0.25 uf / 600v , connected to the standby switch
                          i dont see these on any schematics
                            The schematic from post #3 shows .22uF caps connected to the standby switch. (to the left of switch at HV winding)
                              Ok-- see them now..what is their purpose ?
