Hi all, from sunny Pevensey Bay, Sussex, UK.
Having found this thread after a Google search:
http://music-electronics-forum.com/t12900/
I posted there for advice. I was immediately helped by OC Disroder and J M Fahey.
Thanks guys for your help.
Their first suggestion was to make a new post and refer the old one. Check.
They then suggest posting a schematic - I hope that has appeared here now (not hugely familiar with attaching in forums).
OC suggests thumping the amp on top - I'm waiting for it to warm up as I write this thread.
I've had the amp for 19 years and it's been a gem - it's had a hard life, being stored on my boat when I was a travelling musician in the Mediterranean, then stored in the garage for the last couple of years. I'm kinda thinking it's simple bad connections but i thought I'd have a look online first.
I have read the thread I mention above and tried disconnecting and reconnecting all the leads (with the amp switched off, diconnected and left for several hours in case of capacitors still holding charge), I've pulled and pushed the speaker jack in and out several times to try to dislodge any accumulation of dirt. I also wiggled (gently) all the valves in their sockets, pulled them slightly then pushed back home without actually taking them out. All of the previous is just to try to make sure the connections are all good.
In my other post I asked "Can anyone help by leading me through a diagnostic/repair method?" - J M Fahey asked me - can I be a Tech?
In answer to that:
I'm a fairly resourceful bloke. I was a professional yacht skipper before 'swallowing the anchor' and returning to the UK. I have experience with electronics, electrics, air conditioning, gas installations, marine diesels and a wide range of other stuff. I'm a flight simulator enthusiast and am building a full cockpit in the garage - this involves soldering, programming, building structures, building PCs etc. so I have a wide experience and am open to being directed.
I can handle a soldering iron - I don't have an adjustable one but I have 3 different wattages
I understand schematics but am not experienced with them.
I can identify resistors, capacitors, transistors in schematic and on the PCB etc. but may need more help on less common components.
I can use a multimeter, select the correct mode and scale.
I don't know what is meant by 'inject signal in the amplifier' though.
In summary - I cannot afford a tech, am not one, but I am willing to learn what I don't know and I'm a reasonably capable type.
Advice to carry out procedures in post 50 of previous topic:
Cable between effects loop - has no effect.
Checking solder on input jack, and check voltages on preamp tube plates and/or check plate resistors - I haven't yet dismounted the circuit board.
In any case I'll need guidance on the latter two above.
I hope that's enough info.
Amp is now warm and thumping the top is inconclusive - if I follow my hunch, it seems to be a little better after a thump - i.e. it runs a little longer before the next cut-out. But that's very subjective as the cut-outs are unpredicatble - sometimes for several seconds, sometimes flickering. The amp is flickering on and off on its own while I'm writing, so difficult to know if thumping it has any effect, really.
Thanks in advance for the help.
Roger.
Further info.
While waiting for a reply, I tried putting a jack plug in the reverb foot switch socket. This seemed to help - the amp stayed on without flickering for several minutes. I thought I might have cured it, but eventually it started to play up again.
Believing it may still be a dirty contact problem, I took apart what i could - any leads, valves out (carefully placed in order and gently handled), sprayed everything liberally with contact cleaner. Put a jack plug in each socket and sprayed with contact cleaner while contacts were open. Then moved the jack plug in and out several times.
Put everything back together and switched on in the hope that I'd cured the problem.
Now the green light doesn't come on at all!
Rats.
Hoping for some helping hands here. Gig on Saturday...
In answer to that:
Roger.
Further info.
Rats.
