I'm not clear on whether the Fet also ended up being bad or not and if it was replaced?
fender bassbreaker 45 schematic
Would you please post screen voltage after repair woth power knob at 45W? Or do you remember? I have one in that has plates at 437v and screens at 304v at 45W. And it was brought in for flabby low end. I'm suspecting Vscreen should be a volt or 2 below plates at 45W per a typical design.
Without a schematic this is a tough one. Any thoughts on soldering the Gate to the Drain to eliminate the Output control?Last edited by lowell; 07-26-2018, 04:59 PM.
