hy guys
i have searched for this on the forums but haven't found anything this far.
i have a fender "the twin", with the red knobs. unfortunately the sound is WAYYY to loud.
i've read on the internet, that you can pull two tubes and set the impedance to 8 ohms.
i did that, but the amp started to distort quite early even on the clean channel. so i put those two tubes back in and tried to set the bias and balance. i got values which were way above the desired 0.4V, and i could set the balance even close to 0.
i noticed, that only two of the powertubes (6l6GC) have a "blue glow" inside.
what can i do to get a clean sound again?
replacing preamptubes?
replacing powertubes?
another question is: what is meant by "pulling the two inner tubes" in the manual?
is it (from left to right): 1001 or 0011? (0 being no tube in the socket)
i tried 1001 and when i switched to "High" the amp started to make terrible noises and the left tube started flickering like hell....?
thanks
thanks
